Rocketkid
I have 1981 automatic transmission.
The car starts and goes in gear just fine. It also shifts normal.
The problem is when going uphill I can see the RPM going up while on the same speed, similar to a manual transmission slipping.
I haven't serviced the tranmission for a while would that help?
Is it worth changing the clutch only (since I'm not doing it myslef) or should rebuild the tranmission?
I bought the car used and I put 80K on the transmission. it has 180k now.
Sam
Sam
