corvette66
So i just got my OD unit together. Time to put the trani back in.
Inside the bell hsg. right where the clutch fork comes in, should the bearing and fork be loose? Mine is just hang'n there. Maybe it came loose when i removed the trani. So should it be hang'n loose, or does the bearing clip into the pressure plate? Just dosen't seem right that it is just hang'n there.
When the clutch is pressed into the floor, it pushes that rod forward that moves the clutch fork and bearing into the pressure plate. Seems to me like the fork or bearing should be stiff, or hooked onto something. The shop manual shows nothing. So just wondering. Don't want to run into a problem once the trani is in.
appreciate any help thanx, dan
