R
Richard Cooper
I got a code 24 today. The book says its the vehicle speed sensor. It says to check the Park/Neutral switch and the park/Neutral relay. Can someone tell me where the P/N realy and switch are located? This is my 81 automatic. Is the P/N switch the switch that will only let the car start in Park or neutral? I tried to start the car in drive and it does not start. Also, how do I check the relay? Do I just turn the key to the on position and check to see if the relay clicks? Thanks for any help.
