John '85
Ok, all you code 32 head bangers, I have a good one for you. I have always had a check engine light come on at the same time everyday during my commute to work, and on the way home. With the little GM code reader 'jumper' in the ALDL, the light flashes 32.
I borrow a friend's AutoExray EZ scan 5000 and it shows, no codes! even when I get the light again, at the same location on my drive, I plug in the EZ Scan 5000, and 'no codes'!!!
So I plug in the EZ Scan and leave it powered up on my drive, to look at the parameters along the way. Guess what, the check engine light did not appear during the drive! (the first time it didnt appear!)
When I park in the lot at work, in goes the GM code reader, and you guessed it, light flashes 32.
So frustrating, it makes my ass want to chew Tobacco!
Car runs fine, all parameters are normal.
