Code 32????
  • Thread starter Thread starter 3sacrwd
3
3sacrwd
I searched the archives and did not find much info on this code....I just finished wiring in a new fusible link to my cooling fan. and changed the diff fluid. I started her up and she ran fine. I let it sit, then went to move it back in the garage, and my SES light is on, ran the codes, and am getting a code 32.....What gives......?? Thanks for the help.
K
EGR code
Its something that you shouldnt stress over, because it doesnt really affect performance.
Its usually that the EGR Solenoid/switch needs replacing, or that the EGR pipe is clogged up. Its usually a cheap fix.
I get one on long hwy drives, I ignore it.
Thanks Vader...I will look into both of those items....
I think a dirty O2 sensor can trigger this also. Sometimes it can be intermittent and go away after the engine warms up or after some hard acceleration heats up the O2 sensor. I have removed and cleaned mine and the code doesn't come back for a while.
