W
whitey
I have a 1986 coupe which I recently purchased. When I purchased the car it had code 33 and code 36. replaced both MAF relays and also replaced IAC and TPS and properly adjusted TPS to .62volts. Cleared the codes by disconnecting battery and started car and I still have the same problem only now I just have code 33. When I start car up it idles good for 30 seconds or so and then starts running real rich and will lots of times die. If I accelerate the car it runs fine and if I let it get warm it will then idle perfectly at about 600RPMS and doesn't run rich. I took mass airflow off and cleaned all the connection and the inside of the mass airflow with no residue contact cleaner and this did not help. No drive ability problems drive car one block and it will idle perfect the rest of the time.
