Does anyone know what would cause code P0300 (intermittent/random misfire) to come up on a diagnostic? I had a diagnostic done about an hour ago since I had a check engine light on and have had issues recently with a rough idle (only once the engine comes up to temp). Please let me know if anyone has had this code come up and what needed to be done to correct the problem. FYI, the check engine light went off after the diagnostic was done.
I have recently replaced the following: fuel pump, fuel filter, plugs, plug wires, EGR valve and fuel pressure regulator. In addition, I am unable to locate any vacuum leaks. Could my problem be electrical?
