HI there,
From what you are saying in the mail, I am suspecting that both sides, drivers, and passenger air injection check valves have rusted shut, causing your condition described in the post.
If you reference the diagram attached here, you will see the actual valves. The one toward the top of the page, is the passenger side. This one, you will have to remove the intake manifold to change.
The valves are the round black things, that have a 1" fitting on the end.
I would recommend changing the drivers side, which is the lower in this picture, and then reset the code, and see what comes back.
If I am on my game, you will not see the p0410, you will most likely see a 1416 once this valve is replaced. If this is the case, then you only have to replace the passenger side, and you repair the condition.
As for your TCS codes, the email described more in detail what you should do next.
Please keep us posted on how you make out, c4c5
