coil overs with F45 variable suspension
J
jim currie
coil overs with F51 variable suspension
Are there coil overs shocks that will allow me to retain the F51 variable suspension
yellow_2002_germany
Kokomo, Indiana
2006 Velocity Yellow
I doubt there would be coil overs available. The suspension position arm attaches to the side of the shock body. It tells the computer the position of the suspension to adjust it according to what position, tour, sport, or perf, is selected.
Mr. Lucky
Orange, CA
2004 MY stroker Coupe
I think you were right the first time - it's F45 (unless you have the newer F55). Either way, you'll have to do one of two things to switch to coil-overs:
1. Edit it out of the BCM using a Tech2
2. Install simulators (resistors)
HTH!
