keith6469
Ijust finished installing new poly bushings in the rear of the car, now on the front. Question, I removed the old coil springs, and the new AC Delco springs are shorter and the spring ends are not cut the same as the old ones. So just to make sure they didnt miss box that set, I got another set. Low and behold the other set is the same. Whats the answer. Please help.
