cool air
I took your advice and looked under the hood. The supply tube comes from a box mounted on the fender on the passenger side. I didn't take the wheel off to look but it almost has to be getting it's air from the fender well which would be cold air. I wonder if anyone knows for sure what the piping is. GM corvette engineers have done a fantastic job of designing corvettes over the years and especially now. America can produce world class products and did with the corvette! I think it was Car and Driver just came out with course times somewhere and the corvette Grand Sport and Z06 were right up there and ahead of most other worldly "sports cars" costing way more money.
Good afternoon, yes the air filter is getting cold air threw the fender. The air filter is not the problem. For 95 % of people this car is flawless, and has no overheating or power issues, especially on the street. For the 5% of us that seriously push the car to it's limits on the track, as well as being a street machine, the problem is air flow. The intercooler for the supercharger sit's in front of the regular radiator (and A/C cond.), thereby 1) preheating the air, and 2) and even worse, seriously restrict the amount of air getting to the radiator. I think the key here is to remove the intercooler from in front of the main radiator, thereby giving the cooling system a chance to work. Perhaps splitting it to a couple of smaller radiators with fans, under the hood or under the car somewhere. LG has a kit for $5000 but you have to cut holes in the front facia. It looks cool, but in everyday driving (which my car does 95%of the time) the intercooler would overheat with their system, since the don't add fans, just little radiators. I asked them about that and they replied that fans just slow down the air when on the track. Yes, maybe a little, but when stopped in traffic, the factory setup has the fans pulling air threw the intercooler where their system does not, for them you need to be moving to cool the intercooler. I need to just find a good place to secure a couple small radiators. Splice in to the current the radiator hose to the Intercooler, run it to the new location, and add a radiator with fan (there's a good selection of stuff at Summit Racing as far as radiators, fans, controllers, etc. and get that factory Intercooler out of the way.
I'm sure it can be done for a lot less as well, I'm thinking $600 - $800 in materials if you do the work yourself that should take care of it. I'm looking into it myself, but am open to suggestions.
Besides the overheating, the car is flawless on the track, even with the factory tires, it's blowing everything away except "trailered in purpose built" race cars.
I had the same issues on a C6 Z06. It was fantastic, until I supercharged it, and cut off the airflow to the radiators with an Intercooler, then it would overheat when pushed hard at the track too. Bottom line, the factory radiator is fine, but even the most efficient radiator won't cool properly if it has hardly any air flowing over it. Get the Intercooler out of there and let the radiator do it's job.
