Jim D
Should I buy the column lock bypaas , what percent of Vette's have a problem, and if I have a problem will the dealer fix it fo free. My 99 is no longer under warranty, thanks Jim.
Hi there,
I would suggest that you remove the #27 minifuse from the toeboard inside fuse block.
Leave it out for 3 mins, and then reinstall.
Turn your car on, and hit the auto button, and set your temps for full hot.
After that time, let me know how you do, as this should reset your temperature mode actuators.
Allthebest, c4c5![]()
Paul, I had to disconnect the battery to fix the headlight motor gear, ac was working fine. Same problem again, driver side ac hot and passenger cold. Pulled 27, no luck. what am i doing wrong?
Herbie
HI there,
I would suggest that you might have an actuator problem.
Are there any codes in the HVAC????
It could be that the actuator is not resyncronizing after.
Let us know, c4c5
HI there,
Let us know, c4c5
Will let you know what I find. Talk to you later....Hi there,
I can actually suggest that there is a wiring harness issue, maybe terminal tension at the actuator or at the control head.
There is also a preliminary service document about the actuator NOT being installed correctly in relation to the teeth on the gear, so that when the actuators attempt a rehome, they cannot get full travel.
The actuator is the correct part number, but I would really check to see if the actuator gets full travel.
Also, this can be read with a Tech 2.
Allthebest, c4c5
When was that??My column locked one night and was ok after sitting overnight. took it to the dealer he did the recall and chamged out the actuater and my bill for the free recall was almost $300.
