N
novafink
Hi all, I notice I have some oil leaking in 2 spots under my 96 ce, I haven't jacked it up yet, but curious what some of the common leaks on this motor are. Also it's a six speed car. Thanks for any info!
What Tuna saidnovafink said:Hi all, I notice I have some oil leaking in 2 spots under my 96 ce, I haven't jacked it up yet, but curious what some of the common leaks on this motor are. Also it's a six speed car. Thanks for any info!
I am sure it is oil... I am not sure if it was just coming from the tranny though. I just had the leak fixed on the tranny, so hopefully it all goes awaySkyguy007 said:Are you sure it's oil? The "oil" leak I suspected on my GS turned out to be clutch fluid leaking from worn seals on the slave cylinder. I added clutch fluid and - wow - what a difference in the feel of the clutch. The trans also shifts a lot better than it used to. I understand that most 6-speed failures are due to poor clutch maintenance and now I believe it.
I'm sure the fluid level has been way low since I bought the car in 2003. Considering that it only took a few minutes to disconnect the battery and pull out the computer, I'm ashamed that I hadn't checked the fluid level before.
There's a new slave cylinder (from Doug Rippie Motorsports with their modifications) under my Christmas tree. I'll be replacing the master and slave cylinders and the tubing after the holidays. Curiously, the DRM slave cylinder is priced about the same as the standard part from GM. I'm told that there's much less likelihood of early failure with the DRM part.
What he said....Vettelt193 said:Mine leaks (and has since I bought it). I should have gotten into it by now to fix it, but it really isn't that big of a deal... I just keep waiting until something big breaks to give me a reason. Nothing yet has![]()
