composite rear spring?
  • Thread starter Thread starter xanax4
X
xanax4
i was thinking about switching to the composite spring as my rear spring is starting to sag, can anyone who has one give me the pros and cons thanks rick:m :m
Just took out the origonal fiberglass and went to a vettbrakeproducts compsite this spring. I went with the 330 lb , they say its best weight for a daily driver.
I was very very pleased, I did the shocks at the same time so Im not sure how much diffrence is coming from the spring alone. A much smoother softer ride, it used to hit the bumps hard and no I just kind of glide over them. And no noticable loss in handeling from what I can tell.
I would definitly recomend this spring, however their is definitly some labor involved in the switch.
Rear/transverse-spring, -multi-leaf vs. mono...
Hello Rick: -since the Mono-leaf spring of fiberglass&resin was introduced on the '81C3-Vettes, I don't know what the above respondent is refering to (unless some of them had the seven to nine leaf steel-spring of 1980 and before), --or perhaps he has gone to some later aftermarket of Kevlar or carbon-fiber composite construction! The standard old fiberglass/Mono-spring is plenty good, -but just be sure to install the softess (lowest spring-rate number) unit available; --owing that you want your shock-absorbers to be controlling your vehicles body and wheel inertial-forces, not your spring (think of the spring as just there to barely hold the body-up to desired resting-height, ---that's it!)! The original heavy (hence having about three-times more inertia, thus substantially less-responsive in keeping the wheels on the road than plastic) multi-leaf steel-spring employed the now arcaric 1920's principle of inter-leaf friction as an aid in the control of inertial-forces; --however, the mono-leaf combined with the new generation of improved shock-absorbers provides a far smoother-ride in combination with superior inertial-control. What generally causes either a plastic or steel transverse-spring to break, -is an ineffective shock-absorber (which allows the spring to over-flex and absorbe shock it is not designed to withstand). Oddly, -upon introduction of the C4, Vette/chassis-enginners demonstrated they heavy-handedly didn't then comprehend the "notion that less is more", -and went way to stiff (extremely high spring-rate, -that would jar the fillings out of your teeth!) on the Mono-spring, --instead of specifying properly designed 2-way/Shock-absorbers along with stiffer Anti-roll Bars that could give the control they later in C5's came to understand was attainable via finesse rather than the absurd ride-harshness a stiff-spring creates (all retro bolt-on do-able in a C3). If you indeed switch to the plastic-spring, make sure you include the metal/heat-shield to prevent exhaust-pipes radiant-heat from cooking the plastic!! --To complete the upgrade/change-over, find discussions elsewhere in this forum about which of the latest shocks appear to be preferred for reasons of cost and performance...
~Bob VonHeck in sandiego calif.
:CAC ;stupid :dance
Unless your steel spring is extremely corroded with visible material loss, chances are all it needs is to be disassembled, cleaned, painted, and re-assembled with new liners. In loaded condition, it will be nearly flat by design - it's very rare for a Corvette rear leaf spring to "sag" unless it's had significant material loss from corrosion. NOBODY makes a decent steel replacement spring with the correct shape and rate to maintain correct ride height - save yours if you can.
