malc350
I'm guessing that the reason my TT is so bad on fuel next to my 93 LT1 is mainly down to the inefficiency of the compression ratio (can't remember if it's 7.0 or 7.5:1 as opposed to the LT1's more than 10:1 ratio.
I know that this is for safety reasons, i.e. under boost a high compression ratio might melt pistons but I wondered if anyone is running higher compression without problems?
Interestingly someone pointed out to me the other day that the supercharger kits you can buy for C4s and C5s (with higher compression engines) are recommended to be fitted to stock motors with no internal mods. I'm thinking why can't we run 10:1 compression ratios, using high octane fuel and let our knock sensors take care of the detonation (or maybe use a modified chip?)
Despite my TT having 3.33:1 rear gears against my LT1's 2.59 the overall gearing in top gear (6th vs 4th on 700R4 auto) is about the same - 85 mph is about 2000 rpm.
I posted this sperately to my last post purposely...
