Compression test results - thoughts?
MaineShark
Rockingham County, NH
1979 L82, 1987 Buick Grand National
I just had a compression test done.
145 150
150 160
160 140
170 160
I've been told that this is in the normal range. However, when it comes to tweaking the engine, am I okay, or should I be conservative about it?
Joe
did you put any oil in the cylinders before you started the comp test?? normal test pressure for your motor should be 150 psi. i am kind of surprized to see 170 on your test, but the numbers are good to go for building her up. Brian
No oil. Just empty cylinders. If I was going to really hot-rod it, I would do a full leakdown and such, but I just wanted a general idea of the internal condition.
It clearly isn't tuned very well (the spark plugs were looking pretty sad), but that will shortly no longer be an issue, when I install the TPI system.
Joe
