fhturner
- Joined
- Jun 23, 2003
- Messages
- 218
- Location
- Birmingham, AL
- Corvette
- '00 Torch Red Cpe, 6spd, '90 Red/Saddle ZR-1 #279
Hey Guys (and Gals) [sorry for the loooonnnnggg post!]--
I currently have my Corvette "fix" officially satisfied by my 2000 coupe. Unofficially, though, I've always loved the ZR-1 and have wanted one ever since riding in and driving my friend's Bright Red '90 ZR-1 back in high school. Yesterday, I took a look at another Bright Red '90 with low mileage for sale not too far from here. It has around 13,500 miles on it and the asking price is $20,000. I don't really want to incur more debt or shell out a whole bunch more money, but if I can score a deal on a ZR-1 to "supplement" my C5, I'm all for it!
When I checked out this car, I figured the low mileage would surely mean the car would be pristine. However, this was not exactly the case. While I wouldn't say it was in bad shape, there are many things that are going to need to be done. The biggest problem area for me was the interior... Anyway, I dutifully printed out my CAC Buyer's Checklist and made as many notes as I could. I'm planning to go back to the sales guy with my "gripe sheet", the intent being to push the price down as much as possible to cover the work that will be necessary. Would you guys look at some of my observations/questions and comment on them if you can? If you would, please address how each item would affect the price, in your opinion and/or what you'd expect to pay for this ZR-1.
(1) The body/paint seems to be in good shape, with one very small "spider webbing" spot in the LR fiberglass (had to really look to see it) and one small stone chip in the front of the hood. The black rub strip needs a little attention on the sides at the back, but not much. Mainly, the rub strip needs to be shined up, I believe. So, the outside looks pretty good.
(2) Tires are dry rotted. The dealership will probably be replacing them, but want to add the price of replacements (probably $900-$1000) to the sticker. This doesn't seem right to me. Shouldn't I have the right to expect usable tires w/o having to pay an add'l $1K?
(3) Did the Vacuum System leak check. When turning the key to On, the vacuum pump can be heard running w/o ever stopping. Should I demand a $1K price reduction for that (as suggested in an older thread here)? Also, despite this, engine power seemed to be good, but perhaps not as good as I expected. Can this problem cause the secondaries to "sort of work"? Full power was noticeably stronger than Normal, but still seemed a bit lacking. Maybe it was just me.
(4) On a related note, the Engine Power switch seems a little funky. When turning to Full, the "Full Engine Power" light comes on, but then turns back off when the switch "rolls" off the high spot and clicks into place. I could get it to stay on by "perching" the keyswitch on the high spot. Engine power was noticeably reduced with the switch all the way to Full, where the light turned back off. Is this a serious problem to fix, or is it simple?
(5) The stereo doesn't work. Turning the volume way up, you can start to hear something, then you're startled by a loud tone or static (can't remember exactly-- it just wasn't good). How much of a price reduction should I request for this?
(6) Rotors seemed to exhibit some signs of warpage, but this could have been the hardened, dried out tires. Or could it?
(7) The wheels are not stock, but are of the '92-'96 "turbine" style. While I like the look of these better than the stock "Cuisinart" wheels, I would prefer stock for future collectibility value. Is this a legitimate argument? Price reduction?
(8) The engine bay seems pretty dirty. Not filthy, but not cleaned recently either. I'll have to do it or have it done, so there's more $$$ or time spent. Is this a legitimate gripe (at least as far as haggling)?
(9) The interior seems to be a little faded and somewhat "dried out" on the black areas like the dash, console and steering column (interior color is Saddle). Perhaps this could be brought back with some good cleaning and protectant. Otherwise in the interior: driver's seatback switch on right side of seat is broken; don't know if memory functions work; glovebox door kinda sticks up; console padding and cover has "rolled away" from door itself on passenger side, as if opening is prying the padding away; some plastic lining is hanging out from driver side door, as if door panel was removed and put back on in a half-assed manner (also, two screws along the bottom are silver instead of black, supporting this theory); rearview mirror is loose and gets in the way of the driver's sunshade. Perhaps much of this can be fixed w/o much $$$ but with a lot of TLC. My time is worth $$$ though!
(10) The engine is slow to start up initially. Just chugs and chugs and eventually catches and fires. Bad battery? Bad starter? Carbon buildup? Cost to address?
(11) Aside from the engine power/vacuum issue and the possible rotor warpage, the driveability isn't bad. The suspension feels pretty good, as do the tranny, steering and pedals. At only 13,500, I would expect so! The oil pressure seemed to hover toward the upper end of the scale, though (well, lower end, given the gauge's orientation. Possibly sending unit, or too much oil? Or normal?
Lastly, some details on the car. It was originally delivered to CPC (Chevrolet-Pontiac-Canada) Group Engineering Center in Warren, MI. It was not titled until 1995 @ ~10,000 miles. I'm thinking it was an executive's car or maybe a test vehicle-- would this reduce its value? The VIN ends in 00066, so I'm assuming that means #66 for 1990, correct?
It has the electronic AC and only the glass roof (was hoping for both). I like the low mileage, but it doesn't look to have been kept up meticulously, which is what these cars deserve. I'm okay with that, as long as I can get it back to where it needs to be. But, what does all of this necessary work mean for the price of the car now? $16K? $17K? $18K? Or is $20K fair despite these issues?
That's all I can think of (geez, hope that's enough!). If you've read this far, I thank you. If you can spare a few more minutes to post your thoughts and comments, I'd be even more indebted to you! With any luck, I might be joining your fairly exclusive ranks in the near future!
Thanks!
Fred
Thanks!
Fred
