Convert generator to an altenator
  • Thread starter Thread starter Jims'59
J
Jims'59
I have a 1959 Corvette and was wondering how hard it is to convert it over to an altenator? It currently has a Delco 1102043 generator in it which I believe is 12 volt. If it is 12v then would just replacing the generator with an altenator work? If so what would be a good replacement?
Thanks!
Jim
Hi Jim,
Since you have no replies yet I'll take a stab at it. I am pretty sure it can be done wth a single wire from the alternator to the battery as the regulator is built into the alternator. I did this on my boat quite a few years ago and it was fairly simple and straight forward. You can probably get the correct bracket from the Vette specialty houses. There is also a variety of amperages available for you to choose from. Good luck and I'm sure you will get some more definitive answers here soon.
It's easy to convert from a generator to a single wire alternator. Search the Internet and hot-rod places. This has been common since the 60s. To make it even easier, you want to get one of those alternators with the built in regulator so that you can do what is called the "single wire" conversion. That's the good news. Now for the bad news.
Your ammeter won't work. You'll need to find a bracket. You'll need a new fan belt, and you'll have to figure out what size it is. You'll need to do research and spend money to find all this stuff and then make it all work together. All these problems are very solvable. But if you're like me, the process will involve lots of workarounds; waiting for parts in the mail; driving the other car to the parts store; and, generally solving problems 16 times.
When you're finished, what have you got? No ammeter; something that doesn't look right when you open the hood; and, more juice at idle. What do you need more than 30 or 35 amps for? Killer stereo? Aircraft landing lights for headlights? The stock generator will produce enough juice for the standard equipment for these cars. If you've modified the car so much that its electrical needs are greater, then that's another matter.
magicv8 said:
jims59 - Doesn't your tach run off the generator?
Hey magic good point. He might have to convert to a tach drive dist. too.
Either distributor drive or an electronic conversion. I don't think a distributor drive will run at the same rpm rate as a pulley driven generator. The tach would have to be recalibrated at a speedometer shop to the rpm of a 62-74 tach drive distributor. The 62 cable would probably work. The LH exhaust manifold from a junk yark pickup truck with an alternator is the same as the rams horn Corvette manifolds - since the engine is to the rear of the suspension - like a Corvette. GMC trucks used distributor drive tachometers too.
Interesting. I didn't know that. Years? Chevy too I presume.
Am I missing something here? There is no reason that the ammeter should not work, it does not care if it is getting it's current from a generator or an alternator! The current is flowing down the same wire that the generator used.
Regards, John McGraw
ammeters connect between the alternator/generator and the voltage regulators. if one uses the internally regulated alternator ther is no way to use an ammeter-one should use a voltmeter
On a C1 car the ammmeter does not connect between the generator and the regulator, and I do not believe that it does on any car with a generator. It reads the main red hot wire that feeds the entire car,which is also the wire that comes from the generator. The ammeter will still read any charge or discharge regardless of whether it is a alternator or generator.
Doesn't matter if it's an alternator or generator - both produce charging voltage, fed to the same junction points. No Corvette after 1962 has a series "ammeter" anyway. From 1963 on, what's called an "ammeter" is a sensitive voltmeter that reads the voltage difference between the battery (at the big stud on the starter solenoid) and the alternator output (at the power junction at the horn relay bus that feeds the rest of the car) and displays the voltage difference between those two points as "amps".
