coolant drain plugs in block
paulj1x
San Diego, CA
1999 Torch Red Coupe
I’ve been searching trying to find the coolant drain plugs in the block of my 99 LS1 without any luck. There are a series of equally spaced fully recessed bolts needing a 10 mm socket just above the oil pan, 4 on each side, the driver side one which is furthest back is just above the oil filter, then there’s one maybe 4 to 6 inches in front of this which is easy to get to, then another in front of this just behind the engine mount, then one in the front. I tried the easy one but it had a drop of oil on the end so it looks like this is for the oil galleys. There’s also a brass plug about the size of a quarter in the front which looks promising and another about an inch in diameter, this may be a freeze plug. I didn’t see anything else on the driver’s side, did I miss something?
paul
