Bills money pit
In a effort to reduce engine temp, I recently replaced the water pump with a Stewart stage 1 high flow, added a seven (7) blade fan and HD clutch. Also, the 3 row copper/brass radiator was replaced with a 4 row HD. All radiator seals were replaced. I drove the 81 today in 100 degree temp with ac and the temp did not reach 200 degrees. I am pleased with the results.
My question is as follows: I purchased an air dam seal kit from Dr. Rebuild. The kit contains 5 seals. Two go on either side top of the radiator. The old ones are in place so I know their location. The seal that goes beneath the air cleaner front air duct is evident also. There are two seals remaining but I do not know where they go. The catalog description says the seals mount on the top sides of the front air duct. The old seals are gone and I do not see any evidence where they were attached.
Hopefully, one of you experts will tell we where they attach. Also, a photo would be most appreciated.
Now I must dispose of a 3 year old 3 row radiator and 5 blade fan with a very good clutch.
Thanks!
Bill ;help
Thanks!
Bill ;help
