C
CAJUN C4
My 95's Left Fan is not coming on. When I first purchased it it acted up sometimes it would run and sometimes it wouldn't.I changed all 3 Relay's.Worked fine and I thought I had fixed the Problem. Yesterday with the A/C on the Temp. started to creep up as I was in traffic.Got to 215F.
I stopped and opened the hood and sure enough, the Left Fan was not running. This morning I checked it and the same thing ,No Left Fan.Right side is running on Low and High speeds.Someone along the way,as I am the 3rd owner,re-set the fan's to come on primary 184 and secondary 195 without changing the stock 180F Thermostat.The Fan's have been running forever all the time. I suspect it's the Fan Motor? Am I on the right track as I changed all 3 Relay's.Could it be a PCM Issue? The Right side comes on High when I turn on the A/C.
