cooling fan's fuses-92
B
boblx2a
Cooling fan's fuses
Not sure of a '92 of course but my '85 and '86 has the fuse in the fuse box on the passenger's side of the dash. Don't know why they would have moved it..............
Top
Las Vegas, Nv
1986 Convertible Dark Red Metallic
The fan relay is located in the engine compartment driver side mounted to the back part of the wheel well right in front of the brake master cylinder. :beer
B
boblx2a
Again, not sure if this pertains to a '92 but there may be more then one relay. I also have one (on both the '85 and the '86) that is mounted behind the battery. Pretty hard to reach and I don't remember which relay controls which fan. But if you have two fans you probably have two relays........
94LT1
St Albans UK
94LT1 Coupe
Hello Swedvette
Looks like you have the answer to your question.
Perhaps you could help me.
Vasteras "The Big Meet" Have you been? Is it worth the trip? What can be expected this year?
One things for sure and thats everyone enjoys a good :drink !!
Thanks :beer
Steve
-=Jeff=-
Bartlett, IL. (Chicago Suburb)
1990 ZR-1
on your 92 there are 2 relays on the Left side of the Radiator shroud, one for each fan. They connect to both a fuse and a fusible link for power. My guess is the fans share a fuse with other components. if you have a Helms manual it will state this and show a wiring diagram for both fans
S
swedvette
thaks all for the info's
problem solved had to change the fan
