Cooling flow LT motors in a shark
  • Thread starter Thread starter Mciamp99
M
Mciamp99
I had a question regarding how some of you ran your radiator hoses. I can't tell from any of the pictures. Is the lower hose going to the Thermostat housing? I seem to not have any coolant circulating into the block. On the stock 75 motor the lower radiator hose fed into the water pump and the thermostat emptied into the top of the radiator. With the LT-4, I have them reversed, as I just hoocked them up to the closest neck, which is reversed from the stock 75 motor.
I guess the question is, should I have the bottom radiator hose going into the open part of the waterpump and the top going to the thermostat goosneck? If so, how did you accomplish this as it looks like I would have to make 90 degree turns off each neck? is there an adapter, different goosneck or something that would make this easier?
