Cooling System bleed
jmccloud
Maryland
1995 White Coupe LT-1 Auto
I've located the bleed valve on the thermostat housing and the GM manual shows another just behind the housing and below the throttle body assembly -- but the second one isn't there!
Was this eliminated for a '95? Or am I just going blind?
Anyone know the location or whether it was un-necessary?
Thanks for inputs.
I have noticed the same thing & can't find a valve other than the one on the t-stat.
I guess the terminology they use can cause you to look for a valve that isn't there.
Rabbit
Thanks for the sanity check!
Here's what my '95 C4 ooks like
