Corvair Steering column in a Vette?
I believe the '65 and '66 Corvair Tele can be easily made to work in a Corvette, maybee someone who knows how to do the conversion will respond.
Tom M
"Are you nuts?"
This car is in a MILLION Pieces in my back yard, and it is slowly going back together. Of course I am nuts........
I have been doing research on this and have heard of the swap from at least 3 other sources. Am I on to something here?? Corvairs had telescopic
columns and wooden wheels too.
HMMMM, Lets see:
1. horns are the same
2. t/s switches are the same
3.diameter is unique,... and the same.
anthing else?
64Mike
The Corvair columns that I have looked at look very similiar if not exact to Corvette. The mounts are different, but the column tube is the same. The Tele-column can be converted. Check the 1965 or 1966 Corvette AIM. It willhave a break down of the Column either tele or regular. Good luck, keep us posted on the conversion. oWEN
HMMMM, Lets see:
anthing else?
64Mike
If the length of the tube is the same or longer, and the length of the shaft it roughly the same with the same flexjoint spline - IMO it's a direct fit.
Yes, you can make a corvair column work in a vette. A 65-66 corvair column is very similat to a 64-66 corvette column. You can take the corvair column, remove the spot welded firewall plate from it, and replace the center shaft with a corvette shaft (available new) and it will look and function the same.
Dennis
