So I've been having problems getting into reverse without grinding and shifting also seemed harder than it should have been. As I was reading through Ken's excellent collection of 4+3 articles, I saw the one that talked about the reverse-lockout rod and how you could order a replacement from Corvette Clinic in Florida. I pulled the gearshift stick apart and looked at the rod. VERY worn down one side. So I ordered one.
Apparently he either doesn't get a lot of call for these, or they're mostly for 84-85 MY. Mine arrived without the groove for the OD-enable shaft. Called them, and they expressed a small bit of surprise but were quite willing to fix it. Sent them mine as a template and theirs for repair, got them back by next-day.
Installation is about a 20 minute careful job, and maybe a 1.5 on a scale of 10.
So. $50 for a new rod and 'handle', plus shipping. Is it worth it? I'd say yes. Shifting, especially downshifting, is much smoother, though 1-2 upshift still meets resistance (not as much as before). Reverse engages smoothly and without a sound. That lockout rod must rub against part of the transmission and get 'caught' when it's as worn as mine was.
Anyway, they can be reached at 407.323.7804 during normal east-coast business hours (they're in central Florida). They have a website, www.corvetteclinicinc.com, but they're experiencing ISP problems and it goes up and down.
BTW - I drove the car today without any lockout rod at all. Not recommended... First gear is almost impossible to find; don't even think about 2-1 downshifts unless you're at a stop. There is, though, a noticeable shift improvement in all gears with a rod versus with no rod.
HTH.
[RICHR]
HTH.
[RICHR]
