65TripleBlack
- Joined
- Aug 8, 2003
- Messages
- 128
- Location
- "Down The Shore"
- Corvette
- 1965 black/black/black--1985 red/graphite
How are these best prepped for paint?
Thank you in advance.
Ive never heard of anything like this.Normally ,If there is gel coat on the part at all it is applied by the manufacturer.The Image instructions specify AT LEAST 20 mills of gelcoat before applying primer, sealer, and paint.
65TripleBlack said:Because of the manufacturing process involved, Image panels will cause the baint to blister, unless they are prepared in a very specific way, prior to paint. The Image instructions specify AT LEAST 20 mills of gelcoat before applying primer, sealer, and paint.
JohnZ said:Production Corvette body panels (since mid-'54) have never used ANY sort of gelcoat, either in the panel manufacturing process or in the assembly plant body shop. The outer surface of production press-molded fiberglass panels is simply the cured polyester resin (with the mat/pre-form underneath it), and its surface mirrors the surface of the steel upper mold half.
The original press-mold process was as follows - with the press fully open and both mold halves sprayed with a light film of mold-release compound, the resin-coated fiberglass mat pre-form was placed on the lower half (which formed the inner surface). Then two operators poured measured amounts of the resin/hardener mixture all over the pre-form, covering its entire surface, and the hydraulic press then was closed.
Ron Miller said:John, wouldn't the measured amount of the resin/hardner mixture placed all over the pre-form function as what is commonly referred to as the "gel coat"? If I understand you correctly, this was only placed on the side of the pre-form which was ultimately to become the outer surface of the panel. Just wondering . . .
rlm :cool![]()
JohnZ said:Ron, the pre-form was just a flimsy "veil" of glass strands in the general shape of the finished panel; it was placed on the lower half of the mold, then all the resin was poured over it - the finished panel was the same composition all the way through, from top to bottom, with the pre-form of fiberglass strands becoming the internal reinforcement; polyester resin by itself is very brittle and has little strength, which gives rise to the industry definition for fiberglass panels as FRP, for "fiberglass reinforced plastic".
c5d said:John, so then why would a press-molded panel require application of a gel-coat to prevent paint bubbling?
ID
