P
petroamp
I need help ;help. the polypropelene :confused. tank liner in my '78 has developed cracks and allowed corrosion to take place between the liner and the steel tank, forming pin holes. I've repaired the pin holes with solder & epoxy/fibreglass,but this is probably only a short term solution. As no-one makes these tanks and they are all eventually going to fail does anyone have a solution to this issue? Does POR15 provide a solution with their fuel tank repair kit or is there an aviation fuel tank repair we could use? So hopefully some one has an answer because sooner or later all us '78 to 82 owners are gona be walkin.
:blow
