D
Don.Williams
Well, another surprise. My '98 C5 has about 31,000 miles on it. About a month ago I started hearing noise up front, and it increased to the point that my wife could hear me approaching from a block away.
I couldn't find the problem and took it to a non-dealer repair shop. He took the front accessory drive belt off and the noise went away. He put the belt back on and the noise returned.
Then he rubbed chalk on the ribbed section of the belt and the noise went away for a few hours.
The bottom line is that the crankshaft harmonic balancer, the one which drives the belt, has allowed the pulley section to shift and it wobbles, making the noise. It also wears out belts.
I called around San Diego and found it is a known and common problem, but again it is not one recognized by GM.
It would be interesting to see the ratio of harmonic balancers purchased by Corvette compared to the number of matching C5's produced to date.
My guess, based on a random sample of repair shops and dealers, it that about 5% of the C5's out there have or will have or someday will have this problem.
Oh yes, the repair cost is around $450 for parts and labor. The part itself costs $125.00.
The reason the labor is so high is that the power steering gear, the power steering cooler, both drive belts, and the starter motor have to be removed in order to get to the balancer.
Then you have to do some fancy marking in order to set up the new balancer to match the setup of the old balancer if it was modified during production.
It is indeed a major project to replace it. Check it out in the '98 factory manual, starting on page 6-93.
And of course, this happens after the car is out of warranty.
Am I the only one with this problem?
