Cross Drilled Rotors
caddy
Houston,TX
2005 C6 LeMans Blue
I just ordered a new 2005 C6 and I ordered it without the Z51 option, however the one thing that I really like about the z51 package are the rear cross drilled rotors, I was wondering has anyone out there replaced there stock rotors with Cross Drilled Rotors? and if so what all has to be done?
Is it just the Rotors? or do the Calipers & pads have to be replaced also?
Or can this even be done? and if so how expensive?
thanks
Corvette Junkie
Muncie, Indiana
2008 Black/Red/Black Convertible
If you use the same rotors as on the Z51 you will have to replace the bracket that holds the calipers also. But calipers are the same. There are also after market drilled rotors that are the same size as the standard C6.
