Crossfire Changeover
82RL
Gunter,Texas USA
2000 LT. Pewter Coupe
How difficult to change a crossfire engine to a regular manifold and carb? How would it effect the electronics? Is these even worth while? Presently I'm not having any problems with crossfire, just think the regular manifold,carb would be better. Thanks
H
hotrodd
Crossfire
I changed mine to carb.T he only thing I had to do that amounted to anything was get a bypass fuel regulator to lower pressure to 6-8 lbs.I tucked all the sensor wires away neatly that were used for the crossfire.I guess you could maybe change the fuel pump in the tank but I didnt check that out,the regulator works great.I got an areomotive bypass regulator,about 150.00,not cheap but good qaulity.I hope this helps and I'm not forgetting anything else I had to do.
