crossfire trbl
jimbil208
pa
1982 collectors edition
Hello
I have a 1982 collectors edition.
The engine is lacking power and idle rough.
The check engine light is on.
I removed the air cleaner and found fuel going into both injectors ok.
If I put in a rag and blocked the fuel from the throttle body on the front injector,the engine stalls right away.
If I do the same thing on the rear injector,it seems to idle a little rougher but keeps running. Anyone have any ideas.
Thanks,Jim
Since you have a CEL on, you might want to see what is wrong before doing anything else and go from there.
