Coyote
I have a '96 LT4 and have been having cruise control issues. When on the interstate the car will not maintain speed on a good level grade. I can set it for say, 75 mph. It will hold for a little while and then slowly start slowing down. It is still engaged because when I tap the clutch or brake you can feel it release. I checked the vacuum lines and the throttle for binding and found everything as it should be. Could it be one of the solenoid valves leaking by and not allowing enough vacuum to pull the throttle cable? It doesn't do this all the time, that's what makes it so frustrating. I am really close to disassembling the vacuum module and looking for trouble there. Anybody had this problem?
