yungnbord
I’ve read the threads I was able to search out on my problem but can’t seem to find a solution. Here is a description of what is occurring for me…
I have an 87 that the dash works fine when the headlights are off. As soon as I turn on the headlights I can no longer see the speed, RPM and so on. I can still see the high beam indicator and turn signals. At times when I turn the headlights on the speed and RPM are lit but then slowly dim until they are all the way dark.
Today I removed the faceplate to check the 4 bulbs, they were fine. The light sensor seemed to be working as I can shine the flashlight at it and the bulbs will get brighter. I then turned on the headlights and I watched the bulbs slowly dim down over about 40 seconds. I then, with the headlights on, shined the flashlight into the light sensor and the bulbs brightened back up.
Any ideas?
Any ideas?
