Paranoid
Is there anywhere online where I can find info on decoding a Corvette rear end carrier/diff?
Thanks John,JohnZ said:I don't know if there's something here in the "Model Center" (?) or not. Post the numbers/letters you find stamped on the bottom of the diff housing and we can decode it (assuming it has the original gears in it). The casting number is on the passenger side, above the horizontal "fin", and the casting date is on the driver's side, buried behind the strut rod bracket.
JohnZ said:That was originally a 4.11 Posi for a '69 small-block (U-bolt yoke caps), assembled on 2nd shift at Chevrolet-Warren on August 7, 1969.
Paranoid said:Wow! How can you tell this from the code?
MidShark said:And that's all just off the top of his head! :L
Actually, the big block rears would have a different code, and used heavier duty caps with reg. type bolts, not the u-bolt style.
Rich
Paranoid said:Can I use the HD yokes w/caps on this rear with a BB?
