Nothing at Summit or my local parts stores. I only found it at Jeg's for $40 but it only shows to run on windoze NT, 2000, 98,95. I'm running XP. Does anyone know of an alternative or a place that sells an XP compatible version??
thanks
thanks
it works well but i have not used it much since i retired. the "PRO" version is better if you are into real serious engine building and you need a lot more info to put into the program to get results. any of these programs are just a estimation of power but they are very good at doing comparisons of different parts in the same engine
yeah i used it when i was building circle track motors and figuring cam changes really helped out.I saw the pro version but i dont need anything like that anymore.
What is desktop dyno, and engine analyzer? I assume they are engine programs but do they hook up to the car? What do they tell you? Sorry for asking but this sparked my interest. I would love to get some kind of software to hook up to my car, and monitor engine characteristics.
Forgive me if this question is stupid. So can you start with a stock engine, like my L98 setup. Will it allow you to add mods, like intake, or ported heads, perhaps headers or something like that. Does it have a database of stock engines and the specs of them?
With engine analzyer you can make changes,like heads cam specs,intakes,throttle bodys,carbs,header length,superchargers nitrous,its endless.And it does have a database of models to change and choose from.
If you have a laptop or a home computer in your garage you can hook your car to it and run your 86 through it.Without having to use a scanner.YOu need the software and a cable.
Pat,
What exactly does the scanner do? I assume it shows sensor values and engine parameters like BLM data and knock counts? Does that even make any sense? DFI doesn't use that. I am about to switch my '73 over from the Accel DFI gen 6 to a stock GM ECM, a '727 I believe. I will want to monitor everything I can and change it if possible on the fly like I can do with the DFI. I am trying to figure out what the best tools (software and hardware) are to do this with.
I looked at some TunerCat stuff on the web as well as some other stuff. Didn't really understand it much. I don't know the GM tuning lingo I guess.
I found a guy that claims that the GM ECM's can now be adjusted on the fly at this website -> http://www.customefis.com/rttuning.html Haven't heard of anybody using his stuff though. I think the tool is made by TunerCat.
thanks
