wjs1475
New member
hi, at this stage i have metal top off and removed old face plate by removing bolt attaching computer board to back of plate.
i can't replace new plate without removing computer board along with its white connector. the space is too small to pull the board and connector out. i had heard that if you remove or move the cassette mechanism you can get board and connector out. if this is true how would i do that? what screws and bolts to remove? if another way can you advise. thank you
