C
CharlesBrown
Anyone know if the gas gage read-out on my '88 digital dash is logarithmic? If it isn't, then I've got a problem.:confused
Yep, the gas gauge is junk, but at least it "works". I hate stuff that isn't functioning at all.
Another incentive to keep your tank full, other than the cost of filling an empty tank, and the uncertainty of the gauge... the fuel pump is cooled by your gasoline. If you run with your tank less than 1/2 full, your fuel pump will be running hot.
Are you sure it is at 1/2 tank? I read that the fuel pump is sumerged until the gas gets below a 1/4 tank..![]()
I went from one bar to over a half tank.
