digital readout
  • Thread starter Thread starter mike t
M
mike t
I did blow a fuse when messing about with the cig lighter and a CB radio I was using. I do not know if this is related but I do not get ditital readouts for water temp or oil temp nor voltage readout,did check search for pointers but found none. Fans come on but late. Have shop manual thouth not sure where to look. Any ideas. Thank you.
Look in the back of your shop manual and you will find a fuse circuitry layout....
this will help you to find out what is interrelated with the fuses....that is a GM shop manual for that particular car right????
Hope this helps
Mike
