Dimmer switch
  • Thread starter Thread starter akvette
A
akvette
Dimmer switch went out on my 81 that has a tilt/tele steering wheel. For those of you who have had to change the dimmer switch, any advice? Also, does this require any specialty tools other than a steering wheel puller? Thanks in advance.
Akvette
Found the problem thanks to Jim Shea from corvetteforum. The actuator rod had become disengaged from the dimmer switch. Easy fast fix with the right info.
