Stallion
I'm going to drop the transmission, and I need to disconnect everything in order to get her out of there. I have a couple of questions about it, though. Right above the three shift linkages that go into the transmission, there is an electrical connector (see attached picture) and I don't know what exactly that is. Any ideas? Do I need to disconnect it? How?
Also, the speedometer cable, does that go into the "rear" of the transmission? Right above the rear mount? Well, I unscrewed the cap of where it goes into the transmission and I saw the cable, but it seems that the speedo cable goes straight into the transmission. How am I supposed to disconnect that??
Last question, where the shifter is mounted, I was told that I needed to get that out of there, as said by this picture:
But I was just under the Vette, and it looks like this shifter lever mount is totally independent of the transmission. Do I really need to remove this?
Please help me as soon as possible because tonight I would like to get everything disconnected from the transmission so I'll be able to drop it in the next day or two.
Thanks!
Stallion
Thanks!
Stallion
