display problems
  • Thread starter Thread starter doogie
D
doogie
Hello everyone, I am a newbie to this messageboard and as a Corvette owner. I have a 85 Coupe and it has a bunch of small problems and one of them is that the left side of the display is very dim. The right side is fine. Any suggestions?
Welcome :w You can remove the cluster and replace the bulbs on that side (or all while you're in there) If your blinkers are working, you might not want to mess with those. The other bulbs are 882's which you can get at Walmart, Napa or ?. Do a search for dash bulb replacement and read up if you can.
Others have used different bulbs which they say are a little cooler and not quite as bright.
A few more pics here. http://forus.com/moonunit/corvette/VetteRebuild/DashCluster/
