1st thing you need is a good hoist to pull the engine out. You can rent them at tool supply companies, or just buy one for a couple hundred dollars. I use an old chain hoist, but would love to have a hydraulic lift, you can maneuver the motor up and around easier with a hydraulic lift. You will find that you will use it for alot of other things.
When you connect the hoist to the motor, if you still have the lifting eyes on the intake, you can attach there. Get a chain about 2 1/2 feet long with two 1/2-inch shackles. Run the shackles through the chain, then bolt it to the lifting eyes. If you don't have the lifting eyes, just pull out two intake bolts, one at the rear of the intake on the passenger side, and the other on the front of the motor on the drivers side, and put in stainless bolts that are about 3/4 inches longer than your intake bolts. Just bolt the ends of the chain to the intake using washers so the bolts will not slip through the chain. If your chain ends up too long, get a bolt, nut and washers and pinch the chain together where it is the right length and bolt it.
Also, do you have manual trans or auto? The automatic chassis has a bolt-on crossmember, while the manual trans chassis is welded in. If you have auto, pull the crossmember out so the trans can swing down during the pull. You will have to support the trans with a floor jack when you pull the crossmember. I find it easier to pull the trans out with the motor, that way you can make the trans up to the new motor on the shop floor, rather than in the confined spaces under the Vette.
You will have to pull the hood off so the lift will have access to the motor. Also pull the radiator out, and put a piece of plywood in to protect the A/C condenser. Do not break the A/C system open, just unbolt the compressor from its bracket, and wire it to the fender with a coathanger where it will be out of the way. When you lift the motor off its mounts, it will tend to come forward, so any protection to the condenser is recommended. Make sure all of your fluids are drained out, because the last thing you need when the motor is in the air, is a slippery floor to deal with. If you pull the trans out with the motor, be sure to cap the tailshaft of the trans, so when you swing the motor up, trans fluid will not drain out when it goes up at an angle.
Be sure to protect your fenders with something thick and soft. If I think of anything else, I will post later.
When you install the new motor, just do the opposite what you did on the pull.
There is nothing like the feeling of when you fire that baby up and hearing it come to life after you install it yourself!!
Keep us up to date with pics when you do this!
Bill
