Do 'Jet' thermostatic switches work?
  • Thread starter Thread starter ejrempel
E
ejrempel
I just installed a JET thermostatic fan sensor in the block on the driver's side between #'s 1 and 3. It is supposed to turn the inside fan on at 190 degrees, but won't. What did I do wrong, or is there something else to fix. Are there fuses that can burn out for the inside fan? Need ideas. (the fan works when we jump the relay)
i put in a new fan switch and couldnt get it to work. check the connection on the end of the switch. that was the problem with mine.
[bravo jean!]:upthumbs
