Do Some Vettes Have 2-bolt Mains?
fine69
Maryland / D.C.
'69 Convertible Vette; '72 Z28 Camaro Rally Sport
Hi.
I came to the conclusion that the 350 engine in my 69 is not original since it has 2-bolt mains. However, the guy at the machine shop believes it is the original - he mentioned an HR suffix somewhere on the block. If that's the case, perhaps i should keep this motor.
Is it possible that some Vettes came with 2-bolt mains?
Thank you.
Yes, a lot of vette engines came with 2-bolt mains. I believe in the low horsepower days only the L-82 came with 4-bolts. Sorry don't know specific years or engines, but positive about some vette engines coming with only 2- bolts.
-Tatortot
Tatortot and JohnZ,
Thank you for your replies. Hopefully, I'll get confirmation from the machine shop. This project is full of surprises!
If the engine number matches the VIN then it's the original engine. If they don't match it's not original.
I'm pretty sure the base 350's were all 2 bolt - I know my L48 is.
John
Even my LS-4 454 is a 2 bolt main!
I didn't know the big blocks had 2 bolt mains but as stated above all of the base small blocks used in the C3 did. The performance small blocks (LT-1 and later the L-82) all had 4 bolt mains.
:Steer
:Steer
....only the LS-4 has a 2 bolt. The LS-5 and LS-6 had 4 bolt. The LS4 was only used in '73 and '74 in the Vettes. It is also known as the Truck Motor.
