Don Olson Wiring Diagram - 1967
paul67
Ontario, Canada
1974 convertible
I received mine today from Don for my 1967. A work of art worth framing. I may do so. I can't find the glove box lamp but that is a minor inconvenience. Thanks Don!
Don Olson Wiring Diagram - 1971
Well satisfied with the mine - was able to fine and correct a ground wire . Had
a number of other wiring problems that I could correct . It cut down my time
and I didn't have to use those words .
I guess the only other comment is that it does not seem to identify the fusible links such as at the horn relay and starter. I just replaced mine on the former. But basically I am just whining about a fine product.
Paul - Look at the extreme upper right corner, and the glove box light is at the very top, labeled "inst. compt. lamp & sw.". The fusible links are shown at the starter as the "20 or." and "14 brn", and at the horn relay and voltage regulator as "20 or.".
OK John. My translation was instrument compartment lamp and switch. That could be more specific. I can see the fusible links now, although they are not identified as such. Still, a nice diagram.
Torque Shop
Dream Giveaway
