A
Ala75Vette
On my '75, the passenger side door handle on the outside is 'broke' (it will not open the door). The inside door handle does work, however, so I can open the door from the inside, just not from the outside. I removed the inside door panel and poked around some, but there does not seem to be any 'easy' way to get to the mechanism that connects the outer door handle to the door release mechanism without having to: 1) torch a hole in the door; or 2) remove everything (electric window stuff, etc.), then put it back together again (and hope it works as well as it did before I took it apart....
). Any ideas or help...?
Frank
Frank
