MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
Well, as expected, any used car purchase entails a certain amount of repair work. First and foremost, my doors are giving me trouble.
The passenger door started out nice, but now won't open at all. I'm guessing a linkage came apart, or the latch mechanism broke? More pressing than figuring out what the problem is, is figuring out how to get the door apart, so I can find out. Is there any way to open the door?
The driver's door was rough opening when I got it, and is getting rougher. Looking at the wear marks on the stud on the door frame, as well as the alignment of the door with the body at the rear, it seems obvious that the door is low, and riding heavily on the stud. The fact that the outside handle (which requires you to push down) opens rough, but the inside handle (which does not require any downward force) opens relatively easily also supports that.
Also, the outside handle does not come back up all the way - I assume there is a spring that is broken or weak?
Thanks,
Joe
Thanks,
Joe
