LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
The Problem: Driver's door is not aligned and is difficult to close..
When I open the driver's door just past the body; I can lift up on the end of the door and move it up about 1/4". I know the door is low on the end as the moulding does not line-up.
But the further the door is opened the less up movement I get. At full open the movement is gone.
Is this the door hinge, the hinge pins/bushings or something else?? I can see no wear in the upper bushings, but hard to see and lift at sametime.
Thanks,
LannyL81
Thanks,
LannyL81
