I didn't find that rebuild an easy chore, at all. After getting the parts sent to me, I opened the case to that sick, bwoing sound then heard the falling springs; then sent it for a professional redo by a shop experienced with the O/D.
Your experience may vary.
After some hard staring at the OD flipped upside down with the pan off, I think I will leave the OD as is, bolt it back to the T10 and see what happens. If this were a stock restoration, I would have fun rebuilding the whole box. It bothers a lot of Corvette guys but I really like the transmission and if there was a way worth the headache to build up a spunky/bullet proof 4+3, I wouldn't mind. A video tutorial of installing straight cut gears in a powerglide got me daydreaming on that one.
My dilemma is I have someone building a miniram 383 for me, and the 4+3 route lets me get the car back on the road quicker. The 4 speed section, if my research is worth anything, will be fine for a temporary stand in. I don't think I will ever engage the OD but wouldn't mind it around just in case..... I stumbled on a graph of the 4+3 gears (101 projects for your Corvette) mph x rpm and it shows roughly 2800 rpm for non OD 4th gear at 70 mph through a 3.07 rear. My swapped rear is a 3.45, not sure how much more that will make the rpms climb.
I will use the 4+3 until I feel like coughing up the money for a TKO trans or a ZF. Some quick questions following this decision, however:
I got this trans from someone, had to take them on their word about the 50K mile accumulation. I cracked open the case.....there's an ever-so-small chip in the first to second torque lock slider. I didn't consider it a deal breaker for a temp trans in the least. I ingeniously mixed my shift forks but both look identical in terms of wear. Given the state of the torque lock sliders, I didn't think this would be an issue for engaging the gears but if there is one, I'm all ears.
The lines coming off the OD. I can't find a pic anywhere of where they go to. I don't have the manual in front of me at the moment but I'm assuming they go to a separate auto trans fluid cooler? Not a big deal as Summit sales tons of these, I just can't find a pic of where they mate up to on a stock 4+3 car. Car originally was an auto. I USED to think they mated to the radiator but then I drop the OD pan and the valve bodies dripping trans fluid seem to lead to one of the fittings leaving the OD.....
I plan to wire up the OD on demand trick and plug the kickdown cable hole.
EDIT: Also, Eckler's "kit" with the OD filter and pan gasket gave me a chuckle. Everyone I ever talk to says toss the gasket and just use rtv sealant and save money using the same Ford filter. I forget the model but if someone has that info it is greatly appreciated.
